ATC Toolnumber after restart
Postby CNC_WW » Tue Mar 26, 2024 12:53 pm
Unfortunately I couldn't find anything on this topic.
Is there a possibility for UCCNC to save the tool number when exiting the software?
For me, jobs always end with a tool in the spindle. Then UCCNC is ended and the PC is shut down.
When I start again, the tool number is always set to zero and I have to set the correct number using an "exec.Setcurrenttool - macro". Only then a normal ATC is possible again.
Thank you for your help.
CNC_WW
Re: ATC Toolnumber after restart
Postby ger21 » Wed Mar 27, 2024 10:36 am
Use the Constructor and Deconstructor macros to save and restore the tool #.
M99998
M99999
Postby CNC_WW » Wed Mar 27, 2024 12:36 pm
I tried to experiment with those two macros. But how to i save the Toolnumber, which variable retains its value after a restart? Or do I have to write the number in a Label-ID?
CNC_WW
Postby ger21 » Wed Mar 27, 2024 2:09 pm
Read the label and save it to the profile when closing with exec.Writekey. (M99999)
Then retrieve the tool number with exec.Readkey and use this when UCCNC starts (M99998).
exec.Setcurrenttool(Newtool);
Users browsing this forum: Bing [Bot] and 16 guests
