UC400ETH + Mach3 = problem
Postby NRU » Wed Feb 07, 2024 9:10 am
Hi everyone,
I just changed my pc for a new one which doesn't have //port
So I bought a UC400ETH to connect the new pc. Mach3 and my controller are now working together when I use manual mode, but when i try to use a g-code (created by cambam) it's not working anymore, the cnc make a little mouvement (0.1mm) and its stops....the g-code it's still running in the mach3 windows....
Have you ever had this problem ?
Thanks !
NRU
Re: UC400ETH + Mach3 = problem
Postby cncdrive » Wed Feb 07, 2024 8:48 pm
Try to set the kernel frequency in the UC400ETH plugin in the Plugins menu of Mach3 to a lower value, e.g. try 25kHz for first, because maybe it is too high causing your stepper motors to stall.
Postby NRU » Mon Mar 18, 2024 9:10 am
Hello !
I found the problem, it was the command M3 of the g-code makes the cnc
So, if I use a g-code without the command M3 (start spindle turning) it works perfectly 8-)
And now : do you know how to solve this problem ? I would like to use the g-code with the M3 command ...
NRU
Postby ger21 » Mon Mar 18, 2024 11:05 am
Try creating a new Mach3 profile from scratch.
Postby NRU » Wed Mar 20, 2024 3:22 pm
I tried that....but nothing change
Here you can see my config, is there anything strange ?
NRU
Return to Mach3/4 Discussions
