G41/G42
Rotary axis feedrate compensation
Greolt wrote:I don't think I am likely to get this but would REALLY like it.
Vectric software (Aspire) has the ability to save a toolpath (gcode) directly to Mach3. Mach3 must be running.
So my usual workflow at the machine is to create the toolpath in Aspire and load it directly to Mach3. Then any adjustment or tweek of toolpath is done and again loaded directly to Mach3.
No saving the toolpath and then going to Mach3 and loading said toolpath.
Now I know the first thing I will be told is that I should not have Aspire running at the same time as Mach3. Don't bother. I have been doing it this way for a very long time without a hitch.
Vectric software has this ability built in. It relies on a couple of registry entries that as far as I know Mach3 does no longer load at install. I have a registry file that restores those missing entries.
Because this relies on Vectric and Mach3 doing their part it is unlikely the same feature can happen to UCNC.
But MAYBE, JUST MAYBE I could edit the registry entries to trick it into opening the file in UCCNC instead of Mach3.
Any ideas?
These are the registry entries that need to be added now that Mach3 no longer makes them on install.
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Mach4.Document]
@="Mach4.Document"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Mach4.Document\CLSID]
@="{CA7992B2-2653-4342-8061-D7D385C07809}"
And this is the relevant line in the Vectric Mach3 post processor that would seem to point to those registry entries.
DIRECT_OUTPUT = "Mach|Mach4.Document"
Most likely I am just off in fairy land and this can never happen, but I thought I would put it out there.
There is a graphical screen editor built into the UCCNC.
