Help with Spindle Configuration
Postby pjaromin » Fri Jan 12, 2024 3:57 pm
I have my VFD wired similarly to the diagram in the AXBB-E manual. The A01 analog output controls the frequency perfectly. However the isolated output sends a PWM signal instead of a clean "on/off" when M3 is turned on/off. This results in the spindle not starting at lower frequencies.
When I tried using the "Direction" config it appears to toggle with M4 not M3. What am I missing here???
pjaromin
Re: Help with Spindle Configuration
Postby cncdrive » Sat Jan 13, 2024 3:52 pm
If the isolated output send a PWM signal then that output is configured for spindle PWM probably.
Check your configuration.
You should configure that output as spindle relay and not spindle pwm pin.
