Hi Team,
Keen user of UCCNC; built my own gantry router using an AXBB-E.
Really want to use UCCNC for my next project but not sure if it's the right way to go. Machine is a Deep Hole Drill (kinda like a lathe) and requirements:
1. Uses only two axis (no X axis):
Z axis
B Axis
Both the Z and B axis / spindle are Step/Dir DC servos.
2. Motion controller with 2x analog outputs (0-10v) to control VFDs for oil pump and another function. Planning to use a UC300ETH.
3. Execution of G32 (constant pitch threading - tracking UCCNC supports G32) and G34 (multi-pitch threading, unsure if G34 supported).
4. Custom User Interface / scripting. I want the operator to input parameters (preferably drop down) and execute G code from a screen that I design. Kinda like this screengrab.
Questions:
Can I adjust the 0-10v analogue outputs of a UC300ETH using G-Code?
Does UCCNC support G34 multi-pitch threading?
Can I design operator screens using the UCCNC editor? Can these store user input parameters to be executed by G-Code?
My fallback is using Mach3 with Visual Basic Scripter, which I think was used to create this and is probably the safer pathway. Although, I'd rather stay with UCCNC if possible.
Question: does the UC300ETH Mach3 plugin support G32 and G34?, if so, what releases of Mach3?
I'm tracking that threading on Mach4 isn't supported by the UC300ETH plugin.
I had a look into LinuxCNC but struggled to find a motion controller with two 0-10v analogue outputs without going into multiple daughtercards / HAL etc.
Can anyone help?
Jesse.
