Hi all,
Having problems installing a diode laser.
I bought a diode laser and installed it like recommended by the UCCNC user manual.
Connected the PWM pin on the laser to isolated output 17 pin on port 1 (O17)
Enabled the laser plugin
Set up the laser pin in UCCNC
Problems I am facing at the moment:
1- Laser is on when I start the machine.
2- Running a engraving file through the laser plugin, doesn't work because the PWM is not being applied.
3- When laser pin is set to a value other than 0, the slave axis doesn't move.
Can someone help please
