v1.2116 - Tool Path View blurry
Postby cseyler » Thu Nov 02, 2023 8:06 am
I've just installer the latest beta, and the first thing I noticed is the new Tool Path View rendering system produce a kind of ugly picture compared to the 1.2115 version.
With multi-sampled value set 0, it is barely unreadable, and increasing the multi-sampled value just add a nasty blur. It looks like the framebuffer size is not set correctly, or something like that
Here is a screenshot from the previous 1.2115 version
v1.2115
Here the new version with MSample=0
v1.2116 MS 0
And here, the new version with MSample=4
v1.2116 MS 4
cseyler
Re: v1.2116 - Tool Path View blurry
Postby cncdrive » Thu Nov 02, 2023 8:12 am
The framebuffer size is set correctly as it works perfectly on our computers.
If you will post the g-code file then I will load it on my computer to 1.2116 and will post a printscreen.
I will check the code to see if I find anything.
BTW, can you try it on a different computer?
Also can you tell me your video card type number?
Postby cseyler » Thu Nov 02, 2023 9:37 am
I'm running on a Windows 11 computer with a nvidia quadro T1000
When a speak about wrong frame buffer settings, the look of the view is really depending on the zoom level : the view seems "scaled" instead of redrawn with a new size.
For exemple in "windowed mode", the previous version kept a correct aspect ratio whatever the size of the window. In this latest release, the view is stretched
v1.2115 on top
And the gcode
Plaque2_Milling.TAP
(9.3 KiB) Downloaded 163 times
cseyler
Postby cncdrive » Thu Nov 02, 2023 10:24 am
Yes, I confirm the aspect ratio issue when in Windowed mode and the window is resized, will try to fix this in the next release.
The blurry issue I'm idealess yet, will try to check the code later.
Meanwhile if you can check and compare it on another computer?
Postby cseyler » Thu Nov 02, 2023 10:36 am
The stretching issue could cause my blurry effect : I'm using an ultra-wide screen (3840x1600) And I suspect the stretch is the cause.
I can clearly see "magnified pixels" instead having lines with anti-aliasing effect
I've also checked on another computer (windows 10 Intel UHD Graphics 630)
Here are 2 screenshots : the first is taken when the application in on the laptop screen (1920x1080) and the second, when I connect the laptop on my ultrawide screen
FHD
ultrawide
So, I got similar effect
cseyler
Postby cncdrive » Thu Nov 02, 2023 1:12 pm
OK, thank you for the informations, I will check it in a few days.
Postby cncdrive » Thu Nov 02, 2023 1:36 pm
BTW, is the toolpath not blurry when in windowed mode with original window size?
Postby cseyler » Thu Nov 02, 2023 2:08 pm
cncdrive wrote:BTW, is the toolpath not blurry when in windowed mode with original window size?
Maybe a bit better (but it could be due to the smaller screen), but it is far from "crispier" and readable compared to the previous version
cseyler
Postby cncdrive » Thu Nov 02, 2023 2:36 pm
OK, thank you for the infos, I will check it out later and will try to fix it asap.
I might ask you for testing on your computers when we will have some possible solution.
Postby cseyler » Thu Nov 02, 2023 4:06 pm
Of course, I will test. Feel free to send me "test release" by PM if you want.
cseyler
