Configuration probe
Re: Configuration probe
Postby charliem » Sun Oct 15, 2023 7:28 pm
Can you post a picture if the I/O setup1 Screen?
Regards
Charlie M
charliem
Postby nessa0108 » Sun Oct 15, 2023 7:30 pm
Yes the probe is active in the picture.
nessa0108
Postby nessa0108 » Sun Oct 15, 2023 7:34 pm
nessa0108
Postby charliem » Sun Oct 15, 2023 7:37 pm
Looking at the manual you have everything wired correctly. and you say that the probe has a led that goes from one color to another when activated. so the probe is working. Do you have a volt meter that you can measure the signal side and make sure the signal is going to 0 volts when activated? The other possibility is something is software is not set correctly. HAng in there youll get this figured out. :)
Regards
Charlie M
charliem
Postby charliem » Sun Oct 15, 2023 7:39 pm
You need to check the "active low" check box on what ever probe port and pin you are using.
Regards
Charlie M
charliem
Postby nessa0108 » Sun Oct 15, 2023 7:51 pm
Thanks for your answer!
I don't lose hope. I will try yours advices and I send it on this forum if I resolve my problem.
What can not be set correctly on the software? Can I download specific plugging, or other?
nessa0108
Postby charliem » Sun Oct 15, 2023 8:04 pm
No plugin. On the setup screen1 you need to check the box beside active low for the probe you are using.
Regards
Charlie M
charliem
Postby charliem » Mon Oct 16, 2023 8:54 am
See I think this is the issue. See the blue circle. they need to be checked to indicate active low.
Regards
Charlie M
charliem
Postby nessa0108 » Sun Oct 22, 2023 8:18 pm
charliem wrote:Looking at the manual you have everything wired correctly. and you say that the probe has a led that goes from one color to another when activated. so the probe is working. Do you have a volt meter that you can measure the signal side and make sure the signal is going to 0 volts when activated? The other possibility is something is software is not set correctly. HAng in there youll get this figured out. :)
Thanks a lot!!! You resolved my problem! :D I tested the signal's wire with a voltmeter and it isn't to 0. In fact i added a shielded cable to my probe and my problem cames from here. I changed my cable and everything is all right!
So thank you for your advice and your patience, it's really nice and it got me out of a bind! ;)
nessa0108
Postby charliem » Mon Oct 23, 2023 9:33 am
Glad to see you got it working.
Regards
Charlie M
charliem
Users browsing this forum: Bing [Bot] and 48 guests
