i'm having a problem grasping the subject of manual tool change probing. I downloaded the M6 macro recommended in forum and it works according to my expectations (moves to position, asks to change the tool, then measures and comes back), but probing the workpiece at the beginning is a mystery to me, at least why it behaves this way.
What I am doing:
0) I go to mobile probe position and set it up as "mobile probe position" at lets say Z-20.
1) I go to material
2) I lower the Tool1 to the surface
3) I zero the Z axis to workpiece
4) I save the current as workpiece
And now - it wants to measure the tool against workpiece (makes sense), but what I expect would be: first go up to Z0 or generally high to avoid collisions, do rapid to mobile probe, do rapid to save Z, then probing. Then rapid Z0 (or generally high), then rapid XY to original workpiece position, then rapid to Z3 for example (so just a above material).
instead, the probing FIRST does XY movements to mobile probe position, which means if I have tool on the Z0 (material) it scratches the surface or I am risking breaking the tool, then it goes to safe Z, then lowers to probe and worse even after probing, it does the same, first in the low position rapid XY then go up to Z0.
here the video:
https://www.youtube.com/watch?v=_kQCTLzYT78
what am I missing? what do I not understand? how to change its behaviour?
thanks
