ger21 wrote:Yes. I'm not sure if there's even an Estop at all. I'm not familiar with how the C76 and it's plugin works, but your getting the Axis fault first, which may be causing everything to shut down.
WOOHOO !!!! Got it !! I've been chasing this on and off for 2 weeks and it turned out to be my own dumb wiring mistake.
I had already chased all the major wiring and software components and finally got down to the FWD/STOP and SPEED circuit this morning. I started this test by seeing what would happen if I ran the spindle directly from the VFD touchpad but left all the wire connections between the VFD and C76 in place. The spindle still cut off. So then to see if the wiring was the problem I disconnected the data cables between the VFD and the C76. So the only connection between the VFD and the router was the spindle power cable. Well now.......for the first time since I initially made my spindle connections the spindle ran problem free. So finally a real lead to follow. Up to now nothing had given me any hint as to what might be causing the problem.
The next logical step then was to run the speed control from the VFD and FWD/STOP from the C76. Again the spindle ran problem free. That pretty much narrowed the problem down to the 0-10v circuit for spindle speed control. So I looked closely at the wire and connections and found I had reverse wired the pins for the 0-10v variable voltage output connector. The common from the VFD was on the 0-10v pin and vice versa. Wired backwards. Ugh !! Two weeks of aggravation for something I did myself. And the thing is that I had looked at this a few times along the way and kept seeing it as correct when it was actually backward.
So I switched the wires out and voila.........problem solved. What a relief.
Just an FYI on the error pane in UCCNC. It reads from bottom up instead of top down. If you watch the error messages appear (as I've spent way too much time doing over the past couple weeks) you see they scroll downwards. So the E-Stop error message actually appeared before the Axis Fault message.
As much as I will continue to complain about what I did to myself here in the long run it was a good exercise for learning about the system. I had never done any programming of the VFD so now know how that is done. I also finally completely understand the wiring connections between the VFD and the control. Not to mention what I've learned about setting up UCCNC as I've tried to see if I had something incorrectly set there.
Thanks for your help on this. Every little bit of info adds to finding the solution.
BH
