WHB04B-4 Pendant Plugin
Re: WHB04B-4 Pendant Plugin
Postby FerrumD » Fri May 19, 2023 6:27 pm
Antonyart wrote:Hi to all... is there someone who can send me the plugin for the wireless Pendant WHB04B-6
or will this "WHB04B-4 Pendant_6Axistest.rar" in here will work?
If not please... 3d.antony@gmail.com
viewtopic.php?f=14&t=2449&start=90
second post from the top...
FerrumD
Postby Antonyart » Fri May 19, 2023 10:35 pm
@ FerrumD Thank you...
Antonyart
Postby Battwell » Mon Jun 26, 2023 12:41 pm
shad.
can the whb04 plugin be set to output only 2 decimal places to pendant screen for metric?
Postby shad » Sun Jul 02, 2023 7:38 pm
Unfortunately, the number of decimal places is determined by the firmware of the pendant. It cannot be changed from the plugin.
-- Andrew
UC400ETH
UC300ETH-5LPT
NEURON Lite THC
http://neuroncnc.com/
shad
Postby Battwell » Sun Jul 09, 2023 6:39 pm
ok. another request.
can the encoder count be sent to auxhiliary encoder (eg aux encoder 6)
for something im trying to do... see feature requests.
unless you would like to add it to your plugin :-)
(trycut)
otherwise im going to be stuck with hard wired only.
Postby rabbit88 » Sun Aug 13, 2023 11:46 pm
I have been using one of these pendants for some time now, it works very well, thankyou.
I have one smal.l issue that is likely operator error, if I use the pendant to jog while the program is paused for tool change (ie. top cler the tool to probe next tool), it causes a program
rewind. Am I missing a setting somewhere ? (Jog via the built in with mouse buttons works fine, its only using the mpg that rewinds the program).
rabbit88
Postby adam7425 » Sun Sep 03, 2023 11:09 pm
I have the WHB04B-6 Wireless Pendant and was hoping to use this plugin with UCCNC.
What is the latest ZIP file to download? Has shad been updating the original post #1?
It would be nice to have a curated list of the various downloads, outstanding issues etc at the beginning of this thread for others who come across it.
Also, would share the code in the likes of GitHub be something of interest?
adam7425
Postby aethersis » Mon Jan 29, 2024 11:52 am
Hi, I am planning to buy the same pendant and I am also a programmer. Is there any repository where you have source code of the plugin? I'd gladly help you fix any bugs or issues if there is any support needed.
aethersis
Postby Chaz » Thu Aug 01, 2024 3:26 pm
Just bought a 6 axis version of this.
It will not work at all on the WHB04BPendant Plugin but does work on the Neuron 1.1 version that is referenced on Page 13 of this thread. That works to an extent but there is no config option so cant set any macros or keys - a bit of a waste.
Any idea why the 1.5 Version from @shad doesnt work at all? Is the 6 axis one confirmed to work, could it be the USB port issue?
Chaz
Postby shad » Thu Aug 01, 2024 7:53 pm
Hello!
Can not change the plugin attached on the first page of the topic.
Just use this one.
You may need to install Microsoft Visual C++ 2015-2022 Redistributable
WHB04BPendant.rar
(155.86 KiB) Downloaded 156 times
-- Andrew
UC400ETH
UC300ETH-5LPT
NEURON Lite THC
shad
