Npn NO wiring help
Npn NO wiring help
Postby CNCChris » Tue May 16, 2023 11:30 am
In the manual it shows the sensor gets 24v to sensor and input + and sensor signal goes to input - and ground to 24v -
Isn't that just sending 24v positive to + and -?
Why not have 24v going to sensor and sensor signal wire to input + and sensor ground to input -?
I am wanting to wire 3 npn NO sensors XYZ into one input
Thanks.
CNCChris
Re: Npn NO wiring help
Postby charliem » Wed May 17, 2023 9:22 am
I dont know what sensor you are refering to, but if it can handle 24 volts then yes you are supplying the sensor with 24 v on the + and -. Depending on what type of sensor you have the output will either go to 0 volts or 24 volts.
Regards
Charlie M
charliem
Postby CNCChris » Wed May 17, 2023 9:27 am
It's a 3 wire NPN NO proximity sensor
CNCChris
Postby charliem » Wed May 17, 2023 10:13 am
with it being a NPN then the signal will go to 0 volts when the sensor is activated.
Regards
Charlie M
charliem
