Diagnostic page correct?
Postby SMITYP116 » Thu Apr 27, 2023 11:16 am
I've just noticed something very odd.
All my inputs are green on my diagnostic page...despite nothing being connected. Any inputs that are wired in are working like the cycle start button. But thr state is always high on all input pins...its a UB1.
Paul
SMITYP116
Re: Diagnostic page correct?
Postby dezsoe » Thu Apr 27, 2023 12:19 pm
Yes, it's normal, the unconnected input pins are pulled high.
Postby SMITYP116 » Thu Apr 27, 2023 12:30 pm
I've also noticed that my cycle start button for example is wired in and starts the cycle no problem. You can see the LED Light changing as it should on the physical ub1 BoB. However the diagnostic page does not change despite the button functionality properly. Any ideas please? Thanks
SMITYP116
Postby Sandy san » Tue May 02, 2023 10:03 am
That's really odd. It sounds like there might be a problem with the wires or the way the diagnostic page and the input pins talk to each other. I would recommend double-checking all the connections, and if that doesn't work, you may need to look more closely at the wiring and communication protocol to figure out what could be causing this problem.
Sandy san
