Wrong Offsets (X/Y/Z) after fusion360 Tool Change
Postby FerrumD » Sun Apr 09, 2023 7:28 am
Hi
I've designed a small part in fusion360...
there's three operations in one setup.
First two use the same tool... third op uses a 60° Engraver bit... different tool.
I have homed the part (G54) on one corner, as XYZ Zero... and when I run the code it all works exactly as it should... for the FIRST TOOL.
After the two ops with the first tool, the code calls a G53 X0 Y0 and moves the machine to the machine's coord 0 Position for the tool change.
So far so good.
I swap the tool (the machine does NOT have an ATC (yet)...). And tap on Cycle Start to continue...
it actually calls a G54 again - so in theory, it should be back on the originally set working coordinates..
but the second feature is offset badly on X/Y ...
now the interesting part:
IF I output the second op from Fusion as an individual code... suppressing the first two... it works as intended ...
here's the tool-change segment of the G-Code:
X41.894 Z-5.883
X41.833 Z-5.821
X41.783 Z-5.75
X41.746 Z-5.671
X41.723 Z-5.587
X41.716 Z-5.5
G0 Z15.
M9
G53 G0 Z0.
(Engrave1)
M5
(Move to tool change position)
G53 X0. Y0.
M0 (Pause program for tool change)
T10 M6 (chamfer mill D=6. 6mm Engraver)
S2900 M3
G64
G54
G43 H10
G0 X50.371 Y-16.482
Z15.
Z5.
G1 Z0. F333.3
X50.459 Y-16.192 Z-0.277 F600
X50.545 Y-15.943 Z-0.5
My suspicion is that after the G53, the G54 does somehow not work as I think it should...
thanks for the help...
FerrumD
Re: Wrong Offsets (X/Y/Z) after fusion360 Tool Change
Postby lp_felix » Sun Apr 09, 2023 8:21 pm
Have you made z zero again after change to T10?
lp_felix
Postby FerrumD » Mon Apr 10, 2023 6:19 am
lp_felix wrote:Have you made z zero again after change to T10?
no - and would I need to??
When i set up the part i first home the machine,
Then use my 3d manual probe to define G54 X/Y/Z work offset
The g54 and tool offset must be correct, as otherwise the first operation wouldn’t work either
Only when i have a tool change in the g-code from fusion
X/Y are wrong after that
FerrumD
Postby Delco » Mon Apr 10, 2023 6:38 am
How far out is it ? in XY - maybe loosing steps ?
Why would you go G53 X0 Y0 ????
How are you doing tool change - possible you are moving the steppers while you are doing it ? lots of possibilities without much information being provided ?
Delco
Postby FerrumD » Mon Apr 10, 2023 7:23 am
Delco wrote:How far out is it ? in XY - maybe loosing steps ?
Haven’t measured it, but eyeballing it: about 50mm
Also it seems to be a repeatable error
And happens after the G53
So i don’t think the steppers are losing steps in this case
Is there Anything in the gcode that could throw the G54 out?
FerrumD
Postby Delco » Mon Apr 10, 2023 7:54 am
Nothing in your Gcode shown that would do it.
Delco
Postby FerrumD » Mon Apr 10, 2023 8:10 am
Ah. Well then i shall be hunting that ghost in the machine for a bit
FerrumD
Postby ger21 » Mon Apr 10, 2023 11:23 am
Delete the line with the G53 in it, and see if it's still out.
Postby FerrumD » Tue Apr 11, 2023 9:45 am
ger21 wrote:Delete the line with the G53 in it, and see if it's still out.
I'll give that a try today... maybe replace it with a G28 and see what happens..
FerrumD
Postby FerrumD » Wed Apr 19, 2023 10:41 am
ok for those who're interested in the solution / culprit of the issue:
MASSIVE lost steps..
I found that (alignment issues, now fixed) the X-Axis was over-torquing the pathetic stepper (open loop) for it to loose a LOT of steps.
essentially it got stuck... it would move well and home well, but sometimes a rapid move would "jam" it up enough- this is why this happened sometimes during tool changes...
Solution: proper alignment and tossing the steppers out of the door. the alignment issues were introduced (by me) after a modification I had made ,...
But the sad and silly open loop steppers remained an issue and would loose steps every now and then whilst milling too... so I've treated myself to a set of clearpath SDSK servos... should be at my place by the end of the week.
But it wasn't a software issue...
FerrumD
