Tool Change: button - what does it actually do??
Postby FerrumD » Fri Apr 07, 2023 1:00 pm
Ok. I've got my machine up and running - it was a mild uphill-struggle with a few bits and pieces, but it successfully ran it's first fusion360 generated G-Code yesterday.
what I don't get is this:
on the MAIN Screen:
there's a "CHANGE TOOL" button.... I can enter a tool number and tap on CHANGE TOOL...
but what exactly does this suppose to do?? It does NOT seem to load the corresponding tool offset... so I have to go and manually MDI enter the G43Hxx command to load the tool number.
so what's the point of the "CHANGE TOOL" button?
I ask mostly because of two aspects:
PROBING... I've stored my manual 3D probe as tool #96... and of course the probe has an offset of it's own...
OR when I want to use the mill in "manual" mode"
from what I can tell, clicking on "Change tool" does exactly nothing...
FerrumD
Re: Tool Change: button - what does it actually do??
Postby ger21 » Fri Apr 07, 2023 3:41 pm
According to the documentation, it should run the M6 macro.
Postby dezsoe » Fri Apr 07, 2023 5:29 pm
It runs the M6 macro IF it is enabled. See the general settings.
The M6 macro normally should not apply the tool length offset, it should be in your g-code. However, as other macros, you may edit the M6 macro and insert code to apply the TLO.
Postby FerrumD » Sat Apr 08, 2023 11:27 am
dezsoe wrote:It runs the M6 macro IF it is enabled. See the general settings.
Ah found the setting.... thanks.
I've added a Message output as a test... and now it pops up a test message when I click the tool change button.
Can you elaborate on why the Tool change macro should not call G43Hxx ?
I'm new to this stuff after 20 years of mostly conventional machining and trying to learn...
Or would you rather make a custom macro, I could link that to one of the buttons my WHB04B Remote... to say call G43Hxx after a manual tool change without G-Code running?
FerrumD
Postby dezsoe » Sat Apr 08, 2023 4:08 pm
I think it's a safety thing. The standard exactly states that nothing else should happen in M6 than the tool change itself.
The TLO can be applied both in positive and negative direction: G43 or G44. Also, you may assign the offset of a different tool like M6T1 and G43H5.
Google for the RS274NGC pdf to learn more about the g-code standard. The UCCNC follows this book if possible. Of course, those g- and m-codes that didn't exist when the standard was written cannot follow the book.
Save the following code as a macro as any of M20000 to M21999. You can assign a button with the same number and it will run the macro which sets the TLO to the current tool.
int currenttool = exec.Getcurrenttool();
exec.Code("G43 H" + currenttool.ToString());
Postby ger21 » Sat Apr 08, 2023 4:19 pm
G43 is typically in your g-code.
Postby FerrumD » Sat Apr 08, 2023 7:43 pm
dezsoe wrote:I think it's a safety thing. The standard exactly states that nothing else should happen in M6 than the tool change itself.
Thanks! this is exactly what I needed...
much appreciated!
FerrumD
Postby FerrumD » Sat Apr 08, 2023 7:45 pm
ger21 wrote:G43 is typically in your g-code.
I was aware of that - I was looking for what the manual tool change button does... or should do - as without an ATC the button seems to serve no function and I was wondering what I could use it for in a manual tool change.
But yes it makes sense to keep the G43 out of the actual M6 macro.... and implement a solution like Dezsoe pointed out...
FerrumD
Users browsing this forum: Google [Bot] and 12 guests
