ccw analogue output delta spindle
Postby 4130metalworks » Thu Mar 30, 2023 11:24 pm
hi, I have the axbbe controller with uccnc and want to rotate my delta ac servo ccw and cw so in the future I can do rigid taping (also have some of those semi fixed taping tool holders). As my understanding the axbbe only outputs 0-+10volts and I need 0- -10volt to spin ccw. Would this board be the best way to achieve this? https://www.cnc4pc.com/c89-10vdc-analog ... board.html
what other parts would I need to do rigid taping ? The delta motor has an inbuilt encoder but because of the backlash through the gearbox i presume converting to either belt drive or add an encoder directly to the output shaft would be needed
thanks
4130metalworks
Re: ccw analogue output delta spindle
Postby dezsoe » Sat Apr 01, 2023 3:32 pm
Yes, it seems to do what you need. I found a video about it: https://www.youtube.com/watch?v=WdlczKEvqJg. A different CNC controller and a different motor, but the settings for the C89 are what you need.
