Slave axis steps per unit
Postby Doncis » Sun Jan 29, 2023 8:05 am
Hi.
How can I calibrate small deviation slave axis steps per unit? When I hit save button, Uccnc automatically fill the same value from master axis, I tried manually modify config file, with no success. How can I solve this problem?
UCCNC version 1.2113
Doncis
Re: Slave axis steps per unit
Postby Doncis » Tue Jan 31, 2023 6:16 pm
I wrote macro loop, to constantly change the value. But it works only for display purposes - field show correct value, but real movement uses master axis steps per unit value.
AS3.Setfield(1000.1428,83) ;
AS3.Validatefield(83);
Doncis
Postby cncdrive » Fri Mar 17, 2023 8:37 am
You mean that the master and slave axis has different pitch?
That would require different steps per units values which is not possible currently with UCCNC.
Postby Doncis » Fri Mar 17, 2023 8:44 am
May it will be possible in future?
Doncis
Postby wmgeorge » Sat Mar 18, 2023 11:19 am
Usually a Master and Slave are on the same Axis and work to drive say the X or Y together. Like both of my Y motors. What are you trying to do?
wmgeorge
Postby wmgeorge » Mon Mar 20, 2023 12:06 pm
So why post a question and then don't come back when someone asks why do you need that function??
wmgeorge
Postby Doncis » Thu Mar 23, 2023 7:39 pm
Granite moving gantry machine, one axis with two DFU3210 ballcrews on both sides. Ballscrews may be not from same bath.
0.08mm diaviation per 700mm.
Compensate this deviation is not possible for now.
Doncis
Postby wmgeorge » Thu Mar 23, 2023 11:03 pm
Your talking about 8/100 of a mm over 27.55 inches really? 1 millimeter is equal to 0.03937007874 inches. What are you doing in granite that needs that precision? The temperature difference between those two would be a factor also.
wmgeorge
Postby Doncis » Fri Mar 24, 2023 6:44 am
Try to imagine reamed hole, that missmatch additional 0.08mm
Doncis
Postby wmgeorge » Fri Mar 24, 2023 11:25 am
Thats .003 inch measured over 27.55 inches.
wmgeorge
Users browsing this forum: No registered users and 29 guests
