load % readouts. actual and maximum
Postby Battwell » Sat Mar 04, 2023 11:05 am
https://youtu.be/WBUkqUUSI3s
if you are lucky enough to have uc300eth with 2 analog inputs you can use this.
edit the screen to show the correct field numbers. ( i edited the actual boxes as these are not used on routers) then added the max and actual labels.
code is below. save as m501 and run as a macroloop.
// M501 analog to power percentage readout in actual fields. re numbered to 20701,20702
// run as macroloop.
// settings,io settings 1, analog2 = var# set to 151
// set vfd to output current or torque from its analog output. use this as your signal into analog 2.
// 2 analogs in on uc300eth. other controllers may not have them!
int anavar=151;
int max=502;
double analogzero=0; // adjust to give correct percentage.// value is any reading with spindle off.
double reading=exec.Getvar(anavar);
double maximum=exec.Getvar(max);
double power=(((reading-analogzero)/65536)*100);//
if(AS3.GetLED(50)) // spindle on?
//exec.AddStatusmessage("analog 2 = " +reading);
// SET READING %
AS3.Setfield ((int)power,20701);
if (power >90)
{AS3.SetLED(true, 501);}
else
{AS3.SetLED(false, 501); }
// SET MAXIMUM %
//exec.AddStatusmessage("maximum = " +maximum);
if (reading > maximum)
exec.Setvar(reading,max);
AS3.Setfield ((int)power,20702);
else
// SET TO ZERO IF SPINDLE IS OFF.
//AS3.Setfield (0,20702); // this can clear maximum with spindle off.
AS3.Setfield (0,20701);
exec.Setvar(0,max);
Thread.Sleep(250); // update 4 times per second.
