Saving current Z position into the tool length table.
Postby zerodivide » Mon Oct 26, 2020 8:18 pm
So the way tool offsets work in other controls is you call the tool you need.
Then jog the tool to the top of gauge block/part top/etc and hit the button "Write offset"
that saves the current machine Z position into the current Tool offset number.
Is there something like this in uccnc? Because I am missing it and currently have to remember the values and enter them manually.
Also, do UCCNC input fields at least allow copy/paste functionality?
zerodivide
Re: Saving current Z position into the tool length table.
Postby dezsoe » Tue Oct 27, 2020 10:51 am
A macro can be written to automatically set the tool length. Enable the On-screen keyboard plugin: with that you can copy/paste values.
Postby zerodivide » Wed Dec 16, 2020 4:18 am
Howdy guys,
Ended up writing a plugin to do just that:
https://github.com/swindex/UCCNCMachineZToolSet
when you click on the Tool Z Offset field, a little popup shows.
Click OK and it writes the current Machine Z into the field.
YMMV
zerodivide
Postby hacker77 » Sun Jan 15, 2023 1:12 am
I can't seem to get this to work with the new version of UCCNC 1.2115 Firmware ver 1.0370.
When I try to enter numbers into the tool slot the POPUP screen you refer to flashes then disappers and the program freezes.
Didn't see a new updated version on your github page.
Thanks Richard
hacker77
Postby dhanger » Sun Jan 15, 2023 1:55 pm
If you have the on screen keyboard plugin enabled you don't need any macro, just type in 'MZ' into the keyboard field, hit enter and it will write the current Z machine coordinate into the tool offset field. Same with 'MX' and 'MY' although you wouldn't use those for tool length of course.
dhanger
Postby hacker77 » Fri Jan 27, 2023 2:06 am
Thanks got it working correctly. :D
hacker77
Postby Abakker » Wed Mar 29, 2023 8:03 pm
I'm trying to get this to work as well. Keyboard plugin is working, tool z plugin is on, and when i click in the tool table field, I get the tiny window to flash and then it freezes. @Hacker77, can you post your solution? it seems you had the same problem.
Abakker
Users browsing this forum: No registered users and 19 guests
