ProbeIt for UCCNC has been updated to v. 2.200 and is available for download here:
http://www.craftycnc.com/probeit-for-uccnc/ProbeIt now has a built in GCode viewer/editor, and ability to do some GCode modifications (scale, translate, rotate, flip) and to 'Autolevel' gcode to a surface probed as a 'heightmap'.
Update your prior version by installing to the same UCCNC directory, or install into a new UCCNC installation folder. Note, I've done my best to ensure your current 'settings' saved in the XML file will transfer over, but depending on what prior version you are coming from it isn't guaranteed. Make note of your settings, and you nat have to re-enter some of them and do a 'save settings' in the updated version to update to a current XML settings file. Alternately, delete you're existing XML settings, and on first run, use the default settings, then adjust from there to your preferences.
V2.200:
2/26/23
- Addition of a GCode Editor/viewer on a newly added tab, with following features:
View/play Gcode file
Scale, flip, rotate, mirror the GCode
Manually edit GCode and view changes
Probe a surface to a ‘heightmap’, and ‘Autolevel’ the GCode to the heightmap surface.
Save modified GCode to file and/or import to UCCNC
- Bugfixes:
Issues w/ color picker on main page fixed
Issue w/ part rotation apply button on main page
Changes to the online check for new version to fully disable it via user setting.
Issue w/ ‘Edge Mode’, added a timing delay to fix nuisance skips, fixed messagebox warning for negative edge length entry.
Double check on SafeZ vs Z start point on 3d probing surface routines, asks to change SafeZ to Z start if Z start is higher.
- Updates to user interface and cleanup work.
Buttons now ‘autosize’ on the main probing pages
Added a ‘show’ and ‘hide’ for left panel of probing settings
Re-orgainzed location of DXF/CSV controls
Updated XML settings file reading
Suggestions & bug reports always welcome. If any users have any "I wish I could do this... " requests, please let me know.
