ger21 wrote:It's only on first use now, not every time.
Compiling every time UCCNC is started.
It is though pity that it recompiles all the macro every time UCCNC is started. It should check the folder and if unchanged since last start it should not compile. It is a pretty simple operation to check the folder by calculating the checksum and save it when it is compiled and compare the checksum every time UCCNC is started. It is faster than compiling at every start.
A_Camera wrote:I have done a few more tests. I can't force it to happen in 1.2030, so perhaps I was remembering all wrong and first time I have seen it may have been in 1.2031. On the other hand, it is easy to repeat in 1.2031 and in fact I made a video just to show what I do.
I can also easily repeat it on another computer, happens every time, or at least it seems so to me. Tested so far on two, one Dell desktop and one HP laptop.
Could it be connected to the actual pre-compilation message box? It was not implemented in 1.2030 only the compilation.
