Reset machine coordinates
Postby mazinwoodcraft » Mon Feb 06, 2017 11:15 pm
Hi. On my Chinese 3ax router machine coordinates and current coordinates are different. How can I make in same? Just I don't see any option of that. Program said: A machine axis position software limit was reached.
Thanks.
mazinwoodcraft
Re: Reset machine coordinates
Postby andrewbishop66 » Tue Feb 07, 2017 1:13 pm
Hi
as i understand it software limits are not required if you have limit switches
and machine co and work co are always different unless you zero them when you are at the home position the idea is you can then set 0 xyz where you want to work
hope that helps andrew
andrewbishop66
Postby ger21 » Tue Feb 07, 2017 3:26 pm
Go to the offsets page and set the offsets to zero, and then they'll match.
Softlimits use machine coordinates, so you need to be able to home your machine to a repeatable position.
Postby ger21 » Tue Feb 07, 2017 4:24 pm
I use X and Y machine coordinates for almost everything I do, and just change the Z axis to suit the project.
It's the way most industrial routers work, with pop up locating pins to locate your part on the table.
Postby ger21 » Sun Feb 12, 2017 3:14 pm
I meant to reply to this, but forgot...
Vmax549 wrote:So you are programming all your programs based on teh Machine corrds origin ?? You do not set teh Work X0 Y0 Z0 to teh part Origin ??
Interesting(;-) TP
Correct. Everything is programmed to be placed on the machine at the machine coordinate origin, or to use machine coordinates. On the big industrial routers I've used, you don't even have to zero the Z axis, as the parts are placed on the spoilboard, and the g-code contains the part thickness.
You never use Work offsets ?? I do not know of any Job shops that do it that way not saying it is not done.
At work never. At home, maybe 1% of the time.
Cabinet shop, not a job shop. ;)
Users browsing this forum: No registered users and 39 guests
