Charge pump remains active after program closed
Postby fsli » Wed Oct 19, 2022 1:25 am
Setup:
  • Enable probe plugin
  • Configure charge pump pin and port
  • Enable "Charge pump always on"
  • Save settings
  • Close UCCNC.
Bug reproducer:
  • Restart UCCNC.
  • Confirm that charge pump signal is active.
  • Go to Probe plugin screen, click "I" for help window.
  • Leaving the help window open, close the main program window.
  • Answer "Yes" to the dialog confirming that you want to close the program.
At this point the program is no longer active, but the charge pump is still enabled. Close the help window and the charge pump will turn off.
Frank
fsli
Re: Charge pump remains active after program closed
Postby dezsoe » Wed Oct 19, 2022 3:45 pm
The fact that the main window is closed does not mean that the whole UCCNC is closed. If you check the task manager then you'll find a process of UCCNC which is still active. However, the help window should close when you close UCCNC, I'll check it and fix it. Thanks for the information.
Postby charliem » Sun Oct 30, 2022 10:22 am
I also was having a problem with UCCNC closing. http://www.forum.cncdrive.com/viewtopic.php?f=3&t=3891&p=27569#p27569I disabled all the plugin and only enabled one or two that I use. It may have something to do with that.
Regards
Charlie M
charliem
