my spindle speed is limited. how do i get max speed back
Postby atangwahyudi69 » Sat Aug 27, 2022 8:43 am
Hallo everyone,
I have replaced my spindle to chinese spindle which has 24k rpm speed with shimpoenx E500 VFD. my problem is i only get 5000 max speed that written on UCCNC screen.
would anyone give me some advise.
atangwahyudi69
Re: my spindle speed is limited. how do i get max speed back
Postby Dazp1976 » Sat Aug 27, 2022 11:25 am
VFD are generally not set up fully right out of the box.
You will likely need to change some perameters.
One to look for as an example is the setting for the max hz.
If you have a spindle that goes to 400hz and the vfd is only set to max 100hz. In this event I would expect to see a speed of no more 6krpm possible from spindle without a change.
There could be a couple or a few things that need changing
Read the manual.
Dazp1976
Users browsing this forum: No registered users and 46 guests
