Probe tool issue
Re: Probe tool issue
Postby dezsoe » Mon Aug 22, 2022 5:25 pm
Hi Morfeus80,
Thanks for the debug file, it helped a lot. You are absolutely right, it's a bug. The Ref. current does not count with the corrections (gage and/or diameter). I have to fix it, I'll be back soon.
Postby Morfeus80 » Mon Aug 22, 2022 8:52 pm
Thanks dezsoe,
I am looking forward to get the fix.
Morfeus80
Postby dezsoe » Tue Aug 23, 2022 10:32 pm
Hi Morfeus80,
I think I have a working version. Please, test it and write some feedback.
Watching the movements when the tool returns to the starting position I beleive I'll have to stop the tool a bit above the workpiece, but it needs one more input field to set the distance. Using and removing a gage while the machine is probing seems to be much safer now, so I understand why you need it...
Postby Morfeus80 » Wed Aug 24, 2022 11:43 am
Thanks dezsoe,
I will be able to do some tests at the beginning of next week.
I will update you.
Morfeus80
Postby dezsoe » Wed Aug 24, 2022 12:15 pm
OK, thanks.
Postby Morfeus80 » Mon Aug 29, 2022 10:11 am
Hi dezsoe,
I have tested the the version you sent and I confirm that it is working properly!
Thanks and don't forget to add this to the new UCCNC version.
Morfeus80
Postby dezsoe » Mon Aug 29, 2022 10:42 am
Hi, thanks! :)
Users browsing this forum: MSN [Bot] and 26 guests
