Radius compensation
Radius compensation
Postby BKG » Tue Aug 16, 2022 5:14 pm
Error: Radius compensation is not supported for UCCNC. Please change the compensation type to 'in computer' for the toolpath.
Error at line: 1443
Error in operation: '2D Contour1'
Failed while processing onLinear() for record 491.
Does not UCCNC suport Radius compensation ??
BKG
Re: Radius compensation
Postby Pulcik » Tue Aug 16, 2022 9:37 pm
Can you provide nc file?
I think, UCCNC support it.
Pulcik
Postby BKG » Tue Aug 16, 2022 10:43 pm
Same time chekking about sending jpg, I am not able to send with message
Se atached files Nc is txt
100.txt
NC
(519 Bytes) Downloaded 412 times
Fusion_postprosessor uccnc.txt
Fusion postprosessor
(60.42 KiB) Downloaded 420 times
BKG
Postby ger21 » Tue Aug 16, 2022 10:49 pm
You need an updated Fusion post that supports Comp.
Postby BKG » Tue Aug 16, 2022 11:12 pm
ger21 wrote:You need an updated Fusion post that supports Comp.
Newer then this ??
UCCNC post processor configuration.
$Revision: 43862 c7ba73f08fc3a9941aaf4c8abb06710c9a1c83ce $
$Date: 2022-07-06 07:13:32 $
BKG
Postby Pulcik » Wed Aug 17, 2022 10:25 am
Nice big machine. Want to build something like that in a future.
Here, is modified PP. It should work now. Test it, if it works as intended, so I can put it to mine one in a future.
Test it on G02 and G03 moves too, and use 1.2113 for it. As the newer versions of UCCNC have bug when you use G02 or G03 with Z coordinates, which I reported in earlier.
(60.42 KiB) Downloaded 404 times
Pulcik
Postby BKG » Wed Aug 17, 2022 3:39 pm
Pulcik wrote:Nice big machine. Want to build something like that in a future.
Ah thanks :)
I will test it and came back with the result :)
BKG
Postby BKG » Wed Aug 17, 2022 8:47 pm
Ok, I tryed it shortly, looks like it is compensating the vrong way, it vas going at the outer cirkle
Toolpath
1001.nc
NC file
(1.03 KiB) Downloaded 400 times
BKG
Postby Pulcik » Wed Aug 17, 2022 10:37 pm
I am not with machine, but g-code seems to be correct compare to the picture from F360.
Pulcik
Postby Pulcik » Thu Aug 18, 2022 4:26 pm
I tried it on my machine and it seems good. But, the entering is a bit strange.
It seems, that you have some small radius in "lead in" and "lead out" option. That makes the bit enter and compensate on left side (g41) but the radius of feed in/out is smaller than (my 5 mm bit), so it ends up to close at the beginning. after first call of g02, everything is correct, till lead out.
But that is issue your setting in f360. Other than that, it seems to do what you have on picture, in my case.
Pulcik
