Turn software update?
Re: Turn software update?
Postby rodrigjup@gmail.com » Tue Aug 09, 2022 1:14 pm
The plugin encoder Pin I/O as well as the Mach4 Control input I/O port settings keep losing settings every time I restart Mach4, I saw somewhere in teh forum that this was a problem before and that the UC300Eth plugin was fixed and re-issued. Perhaps same issue with latest Mach 4 revision 4204612? I have UC300eth plugin rev 1004.
As usual, any advice appreciated.
rodrigjup@gmail.com
Postby cncdrive » Wed Aug 10, 2022 12:42 pm
Make sure to install the latest plugin with the UCx00 installer with having internet connection on the computer.
Postby rodrigjup@gmail.com » Wed Aug 10, 2022 12:50 pm
Hi cncdrive, thank you for response .
I downloaded latest from website onto my internet pc and then copied UCx installer onto CNC PC and installed. Is this method an issue (Don't have internet access on my CNC to avoid unwanted viruses etc) ?
What Revision should I get ? I have plugin rev 1004 installed.
Kind regards
JP
rodrigjup@gmail.com
Postby asuratman » Mon Aug 22, 2022 3:43 pm
hi cncdrive,
what status on turn software ? any news on specific date released ?
asuratman
Postby cncdrive » Thu Aug 25, 2022 6:04 pm
We still working on it, especially o nthe G95/G96.
I can't tell you a release date, because it is hard to tell how many bugs we will find in the final/real life testing which we are about to do.
Postby rodrigjup@gmail.com » Sat Sep 17, 2022 6:48 am
I have bought a wifi dongle and , gone to website https://www.cnc4pc.com/uc300eth-etherne ... ler-b.html
and run the automatic installer to auto install the plugin in Mach4. It installed version 1.004 again ??
which version is the latest plugin version and what are the changes made relative to 1.004 ? Wish this info was posted on the website so we don't keep going into forum and having to
ask cncdrive for simple information.
rodrigjup@gmail.com
Postby rodrigjup@gmail.com » Sun Sep 25, 2022 2:10 pm
I guess no reply to previous feedback on profile loss on Mach4 exit. Will have to ask Artsoft to assist I guess...
On a positive note, I have managed to post a simple roughing pass profile from Fusion360 to Mach4 and it works so far !
At this stage I have a working Mach4 lathe profile using UC300ETH controller. Have procured a 1024 PPR encoder that I plan to install in order to test threading function.
rodrigjup@gmail.com
Postby betelgueze » Sun Sep 25, 2022 6:03 pm
Hi rodrigjup@gmail.com.
I dont have any solution for your problem. I just want to ask you if you could post about this problem in an other thread.
Maybe in the Mach thread?
Because everytime I see that there have been something posted in this thread, I hope that there is any news about when the Turn software will come.
so please... :)
betelgueze
Postby nhcnc » Fri Oct 21, 2022 7:21 pm
Would you be willing to let us try a version without constant surface speed machining? Like an alpha test?
nhcnc
Postby asuratman » Sat Nov 05, 2022 12:26 am
What status on new turn software ? Big progress, it will be released soon ?
asuratman
