Edit tool screen
Edit tool screen
Postby BKG » Tue Aug 02, 2022 11:15 am
Hello, I would like to add a label / field to the tool compensation list which, like tool length and tool diameter, should be linked to info in the profile file.
Does anyone have tips or links to literature on the subject?
I for ex do not understand how / when data is loaded into the label.
I'm somewhat used to Visual Basic, which has things like on load, do so and so
BKG
Re: Edit tool screen
Postby ger21 » Tue Aug 02, 2022 12:37 pm
Are you talking about the detailed Windows table you can open, or the normal fields on the screen?
Postby BKG » Tue Aug 02, 2022 2:15 pm
ger21 wrote:Are you talking about the detailed Windows table you can open, or the normal fields on the screen?
Windows table I asume se image
Tool list
BKG
Postby BKG » Tue Aug 02, 2022 2:19 pm
Also, how can I best convert string to int ?
Nead tihis as integer
string New_toolpos = exec.Readkey("Tooltablevalues","ToolPos"+Newtool, "");
string Current_toolpos = exec.Readkey("Tooltablevalues","ToolPos"+Currenttool, "");
BKG
Postby ger21 » Tue Aug 02, 2022 5:45 pm
Windows table I assume see image
No, just standard screen elements. Just use the screen editor to add your own fields. Your user fields will automatically be saved in the profile under UserTextFields I think.
Postby BKG » Tue Aug 02, 2022 5:56 pm
BKG wrote:Also, how can I best convert string to int ?
Fix:
string SNew_toolpos = exec.Readkey("Tooltablevalues","ToolPos"+Newtool, "");
string SCurrent_toolpos = exec.Readkey("Tooltablevalues","ToolPos"+Currenttool, "");
double DNew_toolpos;
double DCurrent_toolpos;
int New_toolpos;
int Current_toolpos;
DNew_toolpos = Convert.ToDouble(SNew_toolpos); //BK String to Double
DCurrent_toolpos = Convert.ToDouble(SCurrent_toolpos); //BK String to Double
New_toolpos = Convert.ToInt16(DNew_toolpos);//BK Double to int
Current_toolpos = Convert.ToInt16(DCurrent_toolpos);//BK Double to int
BKG
Postby BKG » Tue Aug 02, 2022 6:03 pm
what is a windows table ?
BKG
Postby ger21 » Tue Aug 02, 2022 6:23 pm
int New_toolpos = Convert.ToInt16(exec.Readkey("Tooltablevalues","ToolPos", "") + Newtool;
Postby BKG » Sat Aug 13, 2022 10:57 pm
Error message in M6
CS1026 | in line: 168 | error text: Forventet )
CS1026 | in line: 170 | error text: Forventet )
Trying to get the New Slot value for to get right tool from the right toolholder Vers2115
the profile file is in type string ? and the number for toolchange nead to be in Integer ?? isent it so ?
int New_toolpos = Convert.ToInt16(exec.Readkey("Tooltablevalues","Slot"+Newtool,"");
int Current_toolpos = Convert.ToInt16(exec.Readkey("Tooltablevalues","Slot"+Currenttool,"");
BKG
Postby BKG » Sun Aug 14, 2022 8:49 am
This line of code is not ok both in vers 2114 or vers2115
This lines of code is ok in vers2114 but not vers2115 odd message se image
string SNew_toolpos = exec.Readkey("Tooltablevalues","Slot"+Newtool, "");
string SCurrent_toolpos = exec.Readkey("Tooltablevalues","Slot"+Currenttool, "");
int New_toolpos;
error message
BKG
Return to Custom Screensets
