Hey G'day all,
Finally got around to installing the new version of UCCNC, I wish I hadn't lol.
I thought I'd do a fresh install and just copy across my settings, well that didn't work out to well. I had motion x y z everything was moving in the right directions. EXCEPT for Home... what a merry go round.
So I spent a couple of hours chasing my tail. Home instead of going to the left of the machine the way it always had it wanted to go right where there were no switches, Y backwards and Z funny enough went the right way.
Could not get it going, check all my numbers, no typing errors things were just backward for home. Everything else like I said going the right way.
So I thought Ill import my old profile that will fix it, well yup it did and I got the old screenset up on the screen, Home working as intended, all axis no issue. So I thought i'll switch back to the new screen, dr google says goto appearance select screenset and your good to go. Well I stared at the screen looking for this button reading every line (hey guys there is no such animal on the old screen set).
Scratching head, I gave up. So I went to my .pro file edited line 2 and pointed it to the new screenset (why is it called Default2019??????????????????????? if its new I would have expect to see at least 2021 2022>? maybe).
Well that FIXED all my issues new screen set homing and motion working correctly.
So being the anal type, I though ok must have made a typo, too pictures of all my settings and did another fresh install.
Guess what, homing backwards could not get the bloody thing to HOME correctly. I did all the active high low underneath reverse direction it didnt matter what I poked, it was determined to move to the right and not the left no matter what I did.
Deleted that and just went back to what was working.
So taking into account Its all good now.
What have I done wrong, I can't install fresh! Add the numbers and have home running correctly?!?!?! Yet loading old profile and just pointing to new screenset works?
Cheers
