Trouble setting homing pins
Postby Hatchet Job » Wed Jul 27, 2022 9:23 am
Hi there.
I'm a complete newbie to UCCNC and I'm currently setting up my CNC router with an AXBB.
I managed to connect my steppers and get them moving but I can't get the homing pins set.
When I input the pin and port numbers it zeros them when I apply settings.
I've tried both with the AXBB connected and disconnected.
Same happens with the limit settings too.
What am I missing?
Hatchet Job
Re: Trouble setting homing pins
Postby ger21 » Wed Jul 27, 2022 11:11 am
You are likely entering the wrong port or pin numbers. The inputs are port 2, not port 1.
Postby Hatchet Job » Wed Jul 27, 2022 11:54 am
ger21 wrote:You are likely entering the wrong port or pin numbers. The inputs are port 2, not port 1.
Yup port 2 is what I've been inputing.
I've tried all available input pins and the same happens.
Hatchet Job
Postby ger21 » Wed Jul 27, 2022 3:25 pm
Can you show a pic of where you have them wired, and what port and pin numbers you are entering.
This happens when you enter an invalid port and pin number. Many people have been confused about the actual port and pin numbers on the AXBB-E.
Postby Dazp1976 » Wed Jul 27, 2022 4:10 pm
Are you pressing the 'enter' button on keyboard before hitting 'apply'?.
Or putting the numbers in and hitting apply?.
Need to press 'enter' first. Many forget that.
Dazp1976
Postby Hatchet Job » Wed Jul 27, 2022 6:15 pm
Thanks guys.
I'm trying to using the port 2 isolated inputs 11-16 as per the manual.
I figured out to press enter after inputing but when I go to apply the settings all the boxes zero.
It happens wether I have the connections made to the AXBB or not.
I just can't figure it out.
Hatchet Job
Postby ger21 » Wed Jul 27, 2022 7:08 pm
The pins are 1-6, not 11-16.
i1
i2
i3
i4
i5
i6
Postby Dazp1976 » Wed Jul 27, 2022 7:35 pm
ger21 wrote:The pins are 1-6, not 11-16.
i1
i2
i3
i4
i5
i6
'i' not '1' lol.
Easy to see how that can be done tbf.
It's always something stupid.
Dazp1976
Postby Hatchet Job » Wed Jul 27, 2022 7:54 pm
Haa Haa!! magic!
Thanks so much...I knew it had to be something simple/stupid like that.
Hatchet Job
Users browsing this forum: Google [Bot] and 28 guests
