OK So I started out on a win 10 computer with mach3 and after installing the uc400eth plugin , once in mach3 /configure plugins the plugin is there and I enable it and restart mach3 the plugin is disable and will not stay enabled. So I figure it must be a win 10 thing and down grade to win7 sp1. I still get the same thing.
If I enable the plugin I even selected save settings and restart. Its the same thing the plugin is disabled.
Can someone give me a idea as to why this is happening? UCCNC works as expected.
Thanks.
