.NET Framework crash - USB removal
Postby johu » Wed Jun 15, 2022 10:19 am
While plugging in and/or removing a USB device the following .NET Framework crash occured.
I'm using a UCR201, I think that is relevant information.
UCCNC version: 1.2112
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.OverflowException: Arithmetic operation resulted in an overflow.
   at USBClassLibrary.USBClass.GetUSBDevice(UInt32 VID, UInt32 PID, List`1& ListOfDP, Boolean GetCOMPort, Nullable`1 MI)
   at Plugins.PluginForm.USBPort_USBDeviceRemoved(Object sender, USBDeviceEventArgs e)
   at USBClassLibrary.USBClass.ProcessWindowsMessage(Int32 Msg, IntPtr WParam, IntPtr LParam, Boolean& handled)
   at Plugins.PluginForm.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.8.4515.0 built by: NET48REL1LAST_C
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
UCCNC
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/UCCNC/UCCNC.exe
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
    Win32 Version: 4.8.4488.0 built by: NET48REL1LAST_C
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Drawing
    Win32 Version: 4.8.4390.0 built by: NET48REL1LAST_C
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
OpenTK
    Assembly Version: 1.1.0.0
    Win32 Version: 1.1.1664.6217
    CodeBase: file:///C:/UCCNC/OpenTK.DLL
System.Configuration
    Win32 Version: 4.8.4190.0 built by: NET48REL1LAST_B
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Core
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Xml
    Win32 Version: 4.8.4084.0 built by: NET48REL1
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
ୈỲ㬔䙸噤︬玿岱
    Assembly Version: 0.0.65535.65535
OpenTK.GLControl
    CodeBase: file:///C:/UCCNC/OpenTK.GLControl.DLL
OpenTK.Compatibility
    CodeBase: file:///C:/UCCNC/OpenTK.Compatibility.DLL
ILCalc
    Assembly Version: 0.9.7.5
p3jrwdgj
    Assembly Version: 0.0.0.0
AForge.Video.DirectShow
    Assembly Version: 2.2.5.0
    Win32 Version: 2.2.5.0
    CodeBase: file:///C:/UCCNC/AForge.Video.DirectShow.DLL
Microsoft.CSharp
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.CSharp/v4.0_4.0.0.0__b03f5f7f11d50a3a/Microsoft.CSharp.dll
System.Dynamic
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Dynamic/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Dynamic.dll
Anonymously Hosted DynamicMethods Assembly
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/mscorlib/v4.0_4.0.0.0__b77a5c561934e089/mscorlib.dll
tmhowexp
Plugininterface
    CodeBase: file:///C:/UCCNC/Plugininterface.DLL
AutoBackupProfile
    Win32 Version: 1.1.0.0
    CodeBase: file:///C:/UCCNC/Plugins/AutoBackupProfile.dll
AutolevelerCA
    CodeBase: file:///C:/UCCNC/Plugins/AutolevelerCA.dll
Microsoft.VisualBasic
    Assembly Version: 10.0.0.0
    Win32 Version: 14.8.4084.0 built by: NET48REL1
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
C76 Fault Reporting
    CodeBase: file:///C:/UCCNC/Plugins/C76%20Fault%20Reporting.dll
Console
    CodeBase: file:///C:/UCCNC/Plugins/Console.dll
Debugger
    CodeBase: file:///C:/UCCNC/Plugins/Debugger.dll
Diagnostics
    CodeBase: file:///C:/UCCNC/Plugins/Diagnostics.dll
FaultSignals
    Assembly Version: 1.2.0.0
    Win32 Version: 1.2.0.0
    CodeBase: file:///C:/UCCNC/Plugins/FaultSignals.dll
Laserengrave
    CodeBase: file:///C:/UCCNC/Plugins/Laserengrave.dll
Lubricator
    CodeBase: file:///C:/UCCNC/Plugins/Lubricator.dll
Modbusmaster
    Assembly Version: 1.3.0.0
    Win32 Version: 1.3.0.0
    CodeBase: file:///C:/UCCNC/Plugins/Modbusmaster.dll
Pinout
    Assembly Version: 2.5.0.0
    Win32 Version: 2.5.0.0
    CodeBase: file:///C:/UCCNC/Plugins/Pinout.dll
Plugintest
    CodeBase: file:///C:/UCCNC/Plugins/Plugintest.dll
Printer3D
    CodeBase: file:///C:/UCCNC/Plugins/Printer3D.dll
Probing
    CodeBase: file:///C:/UCCNC/Plugins/Probing.dll
Profiler
    CodeBase: file:///C:/UCCNC/Plugins/Profiler.dll
Scope
    CodeBase: file:///C:/UCCNC/Plugins/Scope.dll
UCCAM
    CodeBase: file:///C:/UCCNC/Plugins/UCCAM.dll
UCCNC_OSK
    Assembly Version: 1.7.3.0
    Win32 Version: 1.7.3.0
    CodeBase: file:///C:/UCCNC/Plugins/UCCNC_OSK.dll
UCR200Plugin
    CodeBase: file:///C:/UCCNC/Plugins/UCR200Plugin.dll
UCR201Plugin
    CodeBase: file:///C:/UCCNC/Plugins/UCR201Plugin.dll
Webcamera
    CodeBase: file:///C:/UCCNC/Plugins/Webcamera.dll
Xbox360controller
    CodeBase: file:///C:/UCCNC/Plugins/Xbox360controller.dll
XHC-HB04_pendant
    CodeBase: file:///C:/UCCNC/Plugins/XHC-HB04_pendant.dll
knpuw40s
nnd2q2ne
lgmt3i54
omsepv5u
ciewmapo
waceqseg
plm02owc
r0r115ho
r5jv1thl
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Do you need any more info?
johu
Re: .NET Framework crash - USB removal
Postby johu » Sat Jun 18, 2022 9:11 am
Extra info: using UCR201 Plugin Beta 1.4
johu
Postby ger21 » Sat Jun 18, 2022 10:59 am
The simple answer is don't plugin or unplug it.
You're not supposed to ever unplug USB devices without ejecting them first, but I suspect that might not solve the issue.
Postby twedlake » Sun Oct 09, 2022 10:26 pm
ger21 wrote:The simple answer is don't plugin or unplug it.
this response is about as useless as it gets! NO ONE is unplugging anything. the error pops up after about 30 minutes of inactivity with this plug in running
I'm having the same exact issue..
twedlake
Postby ger21 » Mon Oct 10, 2022 12:59 am
The original post.
Postby cncdrive » Mon Oct 10, 2022 4:23 am
I think this has been fixed, but my collegue dezsoe can confirm it.
And you can disable the USB suspend function in the Windows settings so then Windows will not unpower the device goes idle.
The USB suspend and HDD suspend etc. functions are all should be disabled anyways, because they could cause problems if Windows unexpectadly stopping the HDD or doing things which could cause interrupts in the communication between the computer and the motion controller.
