Using manual pulse generators to control axis.
Postby Delco » Tue May 24, 2022 11:54 pm
Can anyone point me in the right direction to setup 2 manual pulse generators , one to control the X axis and another to control the Y axis.
there is mention of MPG A and MPG B in the maual but no real detail on how to use it ?
Delco
Re: Using manual pulse generators to control axis.
Postby ger21 » Wed May 25, 2022 1:23 am
UCCNC only supports one.
A and B are the two wires from a single MPG.
Postby Delco » Wed May 25, 2022 6:46 am
Damn so I cant make handwheels work , I used to use a mpg contoller but threw it in the cupboard as its a pain to switch axis when manually milling.
Delco
Postby cncdrive » Wed May 25, 2022 10:04 pm
The firmware of the motion controllers already supports it, so it will be easy to implement the 2nd MPG, we will do it soon as it is handy for lathes and UCCNC turn will be soon available.
Postby Delco » Wed May 25, 2022 10:48 pm
That is the exact reason I want it for a lathe build :)
Delco
Users browsing this forum: Bing [Bot] and 20 guests
