uc 100 problems
Re: uc 100 problems
Postby cousinit75 » Fri Jan 14, 2022 2:50 pm
This is the Z controller pins configuration
This is Z controller
cousinit75
Re: uc 100 problems
Postby cousinit75 » Fri Jan 14, 2022 2:57 pm
And this is the X and Y controllers
cousinit75
Re: uc 100 problems
Postby cousinit75 » Thu May 19, 2022 10:47 am
ger21 wrote:The pin numbers for step and direction are different. If you haven't changed any wiring, set them to match what they were before.
Thank you "ger21" I now have both directions in X and Z . I have power to the motor and when I looked into the control box I can see the controller has power and is sending signal via a small green light that lights when a direction buttons pressed and the dros are moving . I hoping it's another setting I've just missed.
cousinit75
Re: uc 100 problems
Postby cousinit75 » Thu May 19, 2022 10:55 am
Hi I managed to successfully install and get working my mach3 and uc100 controller ( the one that converts from paralell to usb). But now im getting this error after upgrading my pc to windows 10 and tried to reinstall my legit license. Anyone else had this?
cousinit75
Re: uc 100 problems
Postby cncdrive » Thu May 19, 2022 8:52 pm
Make sure to enable the .net framework 3.5 in the Windows features.
Re: uc 100 problems
Postby cousinit75 » Fri May 20, 2022 6:18 am
cncdrive wrote:Make sure to enable the .net framework 3.5 in the Windows features.
How exactly do I do that?
cousinit75
Re: uc 100 problems
Postby cncdrive » Sat May 21, 2022 8:22 am
Google it please, it is a Windows thing, so you will find lots of answers.
Re: uc 100 problems
Postby cousinit75 » Sat May 21, 2022 9:36 am
cncdrive wrote:Google it please, it is a Windows thing, so you will find lots of answers.
Then what?????????????
cousinit75
Re: uc 100 problems
Postby cousinit75 » Sat May 21, 2022 10:21 am
Ok done that and it allowed me to select the controller. Now I have the issue that my estop wont reset and I have checked the physical button but it just won reset ??
cousinit75
Re: uc 100 problems
Postby charliem » Sun May 22, 2022 10:55 am
Ok go into the uccnc software and goto configuration/I/OSetup.
Then look and the eStop and make sure you the correct pin and port selected. Also either active high or active low check box.
Regards
Charlie M
charliem
Users browsing this forum: Bing [Bot] and 21 guests
