Manual Tool Change with Probing Screen
Re: Manual Tool Change with Probing Screen
Postby CADdy » Wed Apr 13, 2022 7:23 am
I also have the problem with the M6 macro hanging from time to time. I have found out that this occurs when soft limits are switched on and the Z-axis triggers this. If I turn off the softlimits in the settings, the macro runs through without a problem. However, the problem does not always occur.
Peter
CADdy
Postby kjetil » Wed May 18, 2022 4:20 pm
Hi
can anyone tell me how to set up this touch probe.
I have checked in diag that the lights come on when I press down the probe.
I have also copied the m6 macro from this thread and added it to the software. I have also changed so that the correct position is clear of the macro.
what do i do then?
kjetil
Postby kjetil » Sat May 28, 2022 10:11 am
Hi good people
I have now run some tests with M6 macro and it works well.
How can I get the message about the name of the tool to be changed to.
I use vcarve pro and always name the toolpatch with the name of the tool.
Now I just get up that I have to switch to T2 for example.
Daniel collins gets exact name which tool to switch to ??
can i pay someone to tweek it ?
kjetil
