setup the controlbox from cncdrive
Postby kjetil » Sat Apr 30, 2022 5:25 am
Hi
I bought a complete control box from cnc drive. I have come to the connection of stepper motors. I have 2 stepper motors for my y axis. on the switch cabinet only an input with a y axis is marked, where should that stepper motor be connected?
One more thing, when I stand in front of cnc which motor should where, right left motor ??
Matrica dobozba 5teng.pdf
(104.17 KiB) Downloaded 254 times
kjetil
Re: setup the controlbox from cncdrive
Postby ger21 » Sat Apr 30, 2022 11:32 am
I would wire the second Y motor to the B axis.
Postby Dazp1976 » Sat Apr 30, 2022 12:39 pm
ger21 wrote:I would wire the second Y motor to the B axis.
Agreed.
Can I ask?.
What is a good software for doing electrical drawings like the one in the op's attachment
Dazp1976
Postby cncdrive » Sat Apr 30, 2022 12:43 pm
I think my collegue made it in Altium designer.
Postby cncdrive » Sat Apr 30, 2022 12:44 pm
You can connect the motors to any motor connectors in the control box, then you have to configure the axes as per your connections.
