The Probe sensor was active.
Postby kim@moltved.dk » Mon Apr 25, 2022 5:45 pm
After update from 1.2113 to 1.2115 it start giving the error. "The Probe sensor was active. The operation was aborted"
It is before start moving
It is both in Porbe screen and the Probe bottom.
In the diag. screen ti show not active and also in the Probe screen. If i press the probe it show active.
It is a UC300ETH board and a UCBB. And all other is running with out problem.
It is a win 10 64 bit pro.
I have try to set a Oscilloscope on the input and there is no noice or spike in the signal.
kim@moltved.dk
Re: The Probe sensor was active.
Postby cncdrive » Mon Apr 25, 2022 5:50 pm
Are you using a pendant?
If yes then probably it causing it, we found a bug in the pendant interface which caused probing issues, it was already fixed, but the fixed version was not released yet.
Postby kim@moltved.dk » Mon Apr 25, 2022 6:44 pm
Yes i have a RMC100(UCR200)
I start UCCNC and use keyboard to jog to probe position, then probe no problem.
Then i try to jog with the pendant and probe after and it failed.
When will ther be a update?
kim@moltved.dk
Postby kim@moltved.dk » Sun May 29, 2022 12:14 pm
Hi when is there a update with this fix?
kim@moltved.dk
Postby Tea_Cypher » Sun May 29, 2022 5:19 pm
@cncdrive is there a time line with this fix? I am seeing thr same with ucr201.
Tea_Cypher
Postby cncdrive » Sun May 29, 2022 10:41 pm
We already fixed this, but it was not released yet.
We still working on the lathe mode for the UCCNC and when that will be done then we will make a new release which will contain this bug fix.
We hurrying with the new release as much as possible.
Postby Tea_Cypher » Mon May 30, 2022 11:01 am
@cncdrive
No chance of a hotfix without the new lathe stuff?
Tea_Cypher
Postby kim@moltved.dk » Thu Jun 02, 2022 7:17 pm
Come on, we do not use the lathe function on our machines, it just allows for other errors, but our remote/pendant does not work, due to the error!
Please make a new release with only that fix. PLEASE :-)
kim@moltved.dk
Postby cncdrive » Fri Jun 03, 2022 10:32 am
Here is a quick fix, this is the same as version 1.2115, but with the probe bug fixed: https://drive.google.com/file/d/1grm6Mu ... sp=sharing
We released it under the same software version, because there are no changes compared to 1.2115 except this fix, so only the API version changed.
Postby Tea_Cypher » Fri Jun 03, 2022 6:12 pm
Brillent thanks!
Tea_Cypher
