soft limit randomly occuring, soft limits are not on
Re: soft limit randomly occuring, soft limits are not on
Postby DavidR8 » Tue Apr 12, 2022 8:46 pm
I also get a soft limit notice on my Z even when I'm no where close to the limit.
Machine is homed every time I start it up, Auto Set is checked and the soft limits coordinates are 100% correct.
It seems to be related to when I use the UCR201 to jog the Z axis.
DavidR8
Postby cncdrive » Wed Apr 13, 2022 5:20 pm
If you want us to debug your problem then you should post your profile file to let us see and test with your settings.
Postby DavidR8 » Thu Apr 14, 2022 1:58 am
cncdrive wrote:If you want us to debug your problem then you should post your profile file to let us see and test with your settings.
Here is my profile
PNC.pro
(37.41 KiB) Downloaded 356 times
DavidR8
Postby jwhelget » Mon Apr 25, 2022 5:36 pm
Here is my profile also
I did not have this problem for a few days. Now starting again today. I stop cycle after ok-ing warning. Then rehome, single block program will will start spindle next block g94 but will not advance to next block. Also did a restart of program go a little farther but still getting a soft limit.
321.pro
(37.5 KiB) Downloaded 308 times
jwhelget
Postby cncdrive » Mon Apr 25, 2022 5:53 pm
I would say that it is impossible that you getting an error like that if the softlimits are disabled.
And softlimits have nothing to do with limit switches, they are software programmed setable coordinates range in which you allowing the machine axis to move inside, in other words you defining coordinates boundaries for the axes and if the axes trying to move over those then you getting the softlimit error.
Postby jwhelget » Mon Apr 25, 2022 5:55 pm
The only thing that I can think of changing on my system is the UC100. I did not have this problem with the last one. I think I can find the serial number if you think it would be of value looking at. Let me know
jwhelget
Postby jwhelget » Tue May 03, 2022 4:32 pm
If you think it is impossible to have a softlimit error please explain the screenshoot from my previous posting circling the softlimit reached when I am in the middle of my machine bed.
jwhelget
Postby jwhelget » Sat May 14, 2022 5:53 pm
What is happening? No more assistance .......its still happening it did not magically go away. Thanks
jwhelget
Postby cncdrive » Sun May 15, 2022 4:19 am
I could not reproduce the problem at all, so I don't know why is it happening at you and what to do about it.
I also check the softlimits code in the UCCNC and I see no reason or possibility for this to happen.
Also nobody else reported anything like this.
So, I don't know what to advice you. :(
Postby DavidR8 » Wed May 18, 2022 4:33 pm
cncdrive wrote:I could not reproduce the problem at all, so I don't know why is it happening at you and what to do about it.
Well there are at least two of us having this problem.
DavidR8
