Powering a uc300eth
Powering a uc300eth
Postby jesus638 » Mon Apr 04, 2022 1:19 am
Can the uc300eth-5lpt be powered by the ucsb generated 5V.
jesus638
Re: Powering a uc300eth
Postby Dazp1976 » Mon Apr 04, 2022 9:27 am
jesus638 wrote:Can the uc300eth-5lpt be powered by the ucsb generated 5V.
It's likely it won't work properly.
The ports on the 5lpt prob won't 'register' correctly with breakout boards attached to it.
In other words, some circuits won't be completed.
It's designed the way it is for a reason.
Power the uc300 direct first, then use idc26 cable to get 5v to the ucsb via pin26.
Dazp1976
Postby cncdrive » Mon Apr 04, 2022 9:35 am
You should not do that, because it bypasses the isolation of the UCSB breakout board.
You should use separate powersupplies.
Postby jesus638 » Mon Apr 04, 2022 8:55 pm
jesus638
