gills wrote:I have the booklet, but I don't have a pdf version of my 110v manual. Here is the pdf link to the 220v model. All the function terminologies and PD codes are the same, the voltage is the only difference. Again I am controlling the vfd thru Mach 3. see the manual link here. https://bulkman3d.com/wp-content/upload ... ual.pdf.To add more response to your questions, I haven't turned anything on yet. I am trying to verify all of my Mach 3 setup first. My testing will go as follows: motor movement, small test program run, input tests, switches, e-stop, output test via Mach 3 M3 thru M8 commands, verified on multimeter, last will be the vfd.
gills wrote: Again I am controlling the vfd thru Mach 3. see the manual link here. https://bulkman3d.com/wp-content/upload ... Manual.pdf.
gills wrote:So to operate the spindle thru Mach 3 my wiring from the AXBB-E to the vfd should look like the attached drawing correct?? Mach 3 spindle setting should look like this correct??
Dazp1976 wrote:gills wrote:So to operate the spindle thru Mach 3 my wiring from the AXBB-E to the vfd should look like the attached drawing correct?? Mach 3 spindle setting should look like this correct??
If FOR doesn't work as expected then you need a cheap 24v relay module (low trigger).
Connect:
24V+ ----------------------------- relay +
24V0 from axbb-e --------- relay -
O1 --------------------------------- relay sig
DCM vfd ----------------------- relay com
FOR vfd ------------------------ relay NO
