gills wrote:I am using 32 bit dsp digital 556 size drivers that show a max of 200khz. Wired per UCCNC drawings. What is the port and pin location for the spindle?
For relay control m3/m4 then it's whatever you put it on.
Leave step/dir blank on motors page, enable it only,. Go to outputs, set 2 outputs as m3/m4 using relay pin no's and a blank (unless have 2 relays), set those 2 outputs #'s to m3/m4 on spindle page. Lo/hi will flick on/off.
If using analogue output for the voltage you may need to configure the actual PLUGIN to set AO1 as pwm. Leave step blank still and just select pwm on spin page.
If using a pwm pin via pwm/ana converter use this pin as step.
Might be worth reading through some of the literature for the UC300eth. It is effectively the same controller in the axbb-e.
