More Screenset Issues
Postby Parkgrr » Thu Mar 24, 2022 6:54 am
Seeing this error - CS1010 | in line: 4387 | error text: Newline in constant
After adding a couple of buttons to the "USER" tab of the software. Nothing different than I've done many times. I added 3 buttons which is why I'm guessing there are 3 errors.
Parkgrr
Re: More Screenset Issues
Postby Parkgrr » Thu Mar 24, 2022 7:05 am
I deleted the lines in question and the software started. I rebuilt the features and now it works. Just another ghost in the machine issue with UCCNC I guess.
Parkgrr
Postby ger21 » Thu Mar 24, 2022 11:04 am
Next time you see an issue like this, go into the .ssf file and find the buttons you added, and post those lines from the file. There must have been something set wrong?
I've spent hundreds of hours editing screens, and have never seen a single error.
Postby Parkgrr » Thu Mar 24, 2022 10:54 pm
Very kind Gerry. I got it figured; the issue came right back and after reading your comment and looking closer at the lines I saw that extra “ marks were confusing the software. All 3 problem lines were inch amounts attached to macros that lower the Z offset in varying amounts for use in engraving plywood (so the labels were 1 ply .07” … 1/2 ply .035” etc). I removed the “s and it builds the screen fine now. Thank you
@CNCDrive you may consider making that character illegal for screenset labels.
Parkgrr
Postby spillage » Fri Mar 25, 2022 11:10 am
I sometimes come across the issue of using “ in spreadsheets… the work around is to use two consecutive ‘… ie ‘‘
Bryan
“Simplicity is the ultimate sophistication“ Leonardo Da Vinci
spillage
Postby ger21 » Fri Mar 25, 2022 11:44 am
Users browsing this forum: Google [Bot] and 36 guests
