Stepcraft Screenset with UI in mind
Re: Stepcraft Screenset with UI in mind
Postby 2046 » Wed Mar 16, 2022 11:40 pm
This is where I'm now..
I do not have everything live at the moment. Here are some screenshots from concept making.
- The 3D in the sandy color is awesome I must say, I have it in live dev version and won't go back to black (this thing in preview is not real but quite close, the rel thing looks even better ;) ).
- I moved the offset to the right side of the XYZA input field where the 3 buttons together make more sense, as they literally move the head unlike the zero which zeros the "input field" only.
- The Yellow cancel button kinda spoiled all possible colors one can use. Green, red, yellow, there is nothing left other than blue and that does not help at all.. that being said, I do have a hard time to find the right color/tone for active buttons now.
Any other handy comments?
Postby thegreatwaldo » Thu Mar 17, 2022 8:55 pm
That's a great looking screen. Is that just for stepcraft machines or can that be adapted for other machines ??
Cheers
Andrew
thegreatwaldo
Postby 2046 » Thu Mar 17, 2022 9:54 pm
thegreatwaldo wrote:That's a great looking screen. Is that just for stepcraft machines or can that be adapted for other machines ??
Cheers
Andrew
I would say you can use it with any machine. The screen is just a clothes on top of the UCCNC body, which is the mediator between the machine and the buttons that are mapped onto it.
Well try the first release yourself and let me know if it works for you too.
I curious if it covers your needs.
If the version that is on github now works for you, the new version with more polished pixels that is on the way will make no difference.
https://github.com/twentyfortysix/uccnc_screenset_2046
Postby thegreatwaldo » Fri Mar 18, 2022 8:27 am
Thank you very much for that. I will try it out over the weekend , time allowing.
Regards
Andrew
thegreatwaldo
Postby mikkokui » Sun Mar 20, 2022 7:48 am
I have one suggestion for active/non-active buttons. Some GUIs have buttons with a small led "triangle" on their upper corner, I think they look really cool. Could be one option?
One example:
https://www.youtube.com/watch?v=JG7BNxhunTk&t=2s
mikkokui
Postby Robertspark » Sun Mar 20, 2022 12:53 pm
Just curious what software you created the images with (gimp, inkscape, etc?)
nice screenset
Postby 2046 » Tue Mar 22, 2022 10:25 am
Robertspark wrote:Just curious what software you created the images with (gimp, inkscape, etc?)
nice screenset
Definitely curve program, preferably https://affinity.serif.com/en-us/designer/ you need a lot of automation in the process.
The most recent screenset will be up within week or two, not sooner unfortunately.
Postby Robertspark » Tue Mar 22, 2022 1:11 pm
Thanks very much, not heard of that one before, off to go and read up.
Postby Roby » Tue Mar 22, 2022 11:10 pm
This is the best looking screenset that I have seen. Looking forward to trying it this weekend!
Roby
Postby Roby » Wed Mar 23, 2022 8:47 am
I installed the screenset this evening on an offline profile (no time to try it on a real machine today). This screenset looks really promising!
I wanted to retain my existing macros so here is how I installed the Screenset and enabled it for my existing profile.
1. Checkout or clone the github repository.
2. Copy the relevant files to your UCCNC installation directory. Note that my UCCNC installation is in C:\UCCNC\
Copy uccnc_screenset_2046\UCCNC\Screens\Stepcraft_2046.ssf to C:\UCCNC\Screens\
Copy the uccnc_screenset_2046\UCCNC\Flashscreen\BMP\Stepcraft_2046 folder to C:\UCCNC\Flashscreen\BMP\
3. Edit C:\UCCNC\Profiles\Default.pro (your profile file may vary) and change the mainscreenfilename entry as follows:
mainscreenfilename=Stepcraft_2046
I noticed the more recent screenshots look even more polished, so I am really looking forward to the next update! One small suggestion - I've always wanted a screenset which shows the minimum Z of a job on the main screen as this is the one thing I check before running every job. Not sure if this is just me, so I just thought I'd throw this out there.
I'll aim to provide more detailed feedback once I've used the screen on some real hardware. Thank you for sharing your hard work and well done!
Roby
Roby
Return to Custom Screensets
