Error setting AXXBE and Huanyang HY03D023b
Postby macpoy26 » Mon Feb 21, 2022 9:19 am
Hello
I debute with UCCNC :P
I have a settings problem on the 0-10V command. :oops:
Here are the UCCNC configuration screens:
Here are the parameters of the VFD:
P3 : 400
P4 : 400
P5 : 400
P11 : 100
P72 : 400
P73 : 100
P144 : 3000
Here are the analog values identified:
relevé vitesse.JPG (28.67 KiB) Viewed 4785 times
What is the parameter that is not good?
Thank you for your help :P
Claude
macpoy26
Re: Error setting AXXBE and Huanyang HY03D023b
Postby ger21 » Mon Feb 21, 2022 11:42 am
Try PWM Min Duty at 25%
Postby macpoy26 » Mon Feb 21, 2022 12:45 pm
ger21 wrote:Try PWM Min Duty at 25%
Hello
Thanks for your help
I tried to play with this parameter.
Here is the result 25%
relevé vitesse 2.JPG (21.27 KiB) Viewed 4777 times
Do you have another idea?
macpoy26
Postby macpoy26 » Wed Feb 23, 2022 10:11 am
I continued to look for where the problem comes from.
I made tension measurements on the AO1 exit.
relevé tension vitesse.JPG (17 KiB) Viewed 4735 times
As it seemed to me that the card did not deliver more than 5V to 100%, I repositioned the strap on the choice exit 0-5V.
And the it works !!!!! :)
relevé tension vitesse avec cavalier 2.JPG (24.92 KiB) Viewed 4735 times
I have an analog value up to 10V
But I do not understand why? :roll:
macpoy26
Users browsing this forum: MSNbot Media and 12 guests
