mach3 com RNR ECO motion
Postby fcgfilho@gmail.com » Tue Feb 22, 2022 2:56 pm
Instalei e configurei a placa controladora RNR no software MACH3, em máquina cnc router com eixo X, Z e Y com A escravo. Ao executar um arquivo o resultado foi surpreendente. Essa é a primeira vez que uso esse programa com essa placa. As imagens mostram o resultados.
Sketchup part layout - sketchucam plugin
milling result
fcgfilho@gmail.com
Re: mach3 com RNR ECO motion
Postby ger21 » Tue Feb 22, 2022 3:26 pm
I installed and configured the RNR controller board in MACH3 software, in a cnc router machine with X, Z and Y axis with slave A. When executing a file the result was surprising. This is the first time I use this program with this card. The images show the results.
This forum is for CNC Drive motion controllers.
And this is why most of us switched to UCCNC. :D
Postby fcgfilho@gmail.com » Tue Feb 22, 2022 8:58 pm
Most are not all.
fcgfilho@gmail.com
Postby ger21 » Wed Feb 23, 2022 12:04 am
The problem is your acceleration is set to low.
Also, set Stop CV on angles to 89.
Postby cncdrive » Wed Feb 23, 2022 2:01 am
What Ger21 wanted to say is that this forum is for the CNCdrive motion controllers.
Our controllers works with Mach3 and Mach4 and UCCNC softwares and this forum is to support our controllers.
You asking for help about a Chinese motion controllers which has nothing to do with our products and with Mach3 which is again not our product.
So, basically you are on the wrong forum.
Maybe try the machsupport forum it is to support the MAch3/4 softwares as they are the developers of Mach3, so I'm sure you will be welcomed to ask your questions on their forum.
Return to Mach3/4 Discussions
Users browsing this forum: Google [Bot] and 1 guest
