Multi-IO-Interface over RS485
Postby CADdy » Sat Feb 05, 2022 11:35 am
Hi gents,
is it possible to use this multi-IO-Interface with UCCNC? It is connected via RS485 to the PC.
Or would have to program something special for that?
Peter
CADdy
Re: Multi-IO-Interface over RS485
Postby ger21 » Sat Feb 05, 2022 12:56 pm
It says Modbus, so yes, you can communicate with it via Modbus in UCCNC.
But, I don't think you can use it like a normal breakout board, where you just assign ports and pins.
Postby CADdy » Sat Feb 05, 2022 4:41 pm
Hi Gerry,
I didn't want to use it as a BOB. I want to use it to read signals from an ATC spindle (tool locked, clamp open, clamp closed and so on) and to control pneumatic valves.
The other way is, I buy an UC300ETH controller. But then I need a new license for UCCNC. I think, it is not possible to transfer my license to the UC300ETH.
Peter
CADdy
Postby dezsoe » Sat Feb 05, 2022 4:43 pm
This card seems to be good for what you want to use it. Do you have a link to this card?
Postby CADdy » Sat Feb 05, 2022 8:33 pm
Hi dezsoe,
we make a deal: I give you the link and you give me a tip, how to use this card with UCCNC :lol:
https://de.aliexpress.com/item/32881049 ... LI3Hp&mp=1
Peter
CADdy
Postby fixebr » Sun Feb 06, 2022 7:50 pm
a manual should go to this board, which indicates which command should be sent to which register to turn on a specific output, or in which register the state of the board's inputs is located.
If there is no manual, write to the seller on Ali, let you watch.
Install the QModBus program, connect via usb-rs485 (or eth-rs485) to the computer and try sending the read register command according to the manual.
Then, in UCCNC, you type commands in the macro that turn on the outputs and read their values. There is a version of modbusmaster for this - you create a connection there to this pluggable register, and then control by connection number.
My English is bad, so you're reading machine translation results. Alas.
fixebr
Postby dezsoe » Mon Feb 07, 2022 3:31 pm
Hi Peter,
I couldn't find any documentation. It will be a nice job... If you know the parameters then the ModbusMaster plugin can handle the connection.
Postby CADdy » Mon Feb 07, 2022 8:55 pm
Thanks for your answers. I'll order one of these interfaces and hope I can make it work. Let's see...
Peter
CADdy
Postby CADdy » Mon Feb 07, 2022 9:11 pm
On this page there are a few address and register details:
https://www.aliexpress.com/i/32879424433.html
You must click "show all".
It is of course very difficult to program something without documentation.
Peter
CADdy
Postby dezsoe » Mon Feb 07, 2022 9:39 pm
Nice manual! :D (But more than nothing.)
Users browsing this forum: Bing [Bot], Google [Bot] and 16 guests
