I am making items in hardwood that are 50mm x 35mm x 6mm. I generally run the blanks which are on average 200mm long across a planer and then a thicknesser to get my thickness smooth and accurate. The problem with this is that it is time consuming. I found that if I just put the rough blanks in my Stepcraft 420 with a 3mm end mill I can mill off a relatively clean surface with a 50% overlap in seconds. This saves me a lot of time and effort. I then finish with sanding.
I have created a template in Vcarve Pro as follows. Pocket toolpath cutting at a depth of 0.025 mm across the workpiece surface.
At the moment I am rewinding the toolpath file and resetting the tool height to take another .025 cut. What I want to achieve is to be able to jog down 0.025 after each run until the surface or thickness is where I want.
I am obviously not doing this correctly. I assume that if I type in the z axis line .025mm it will move down to the correct amount and then run the toolpath again.
Is this the easiest procedure or is there a button I can customise to jog down .025 just with one click?
