Cutting on the bottom side?
Postby eradicatore » Thu Feb 03, 2022 7:27 pm
I want to make a trivet for valentine's day. I'm close, but I'm not sure how to "cut from the bottom". Right now I have this:
How can I cut the cross pattern on the bottom side of that board? Or do I have to just drill two alignment pin holes, and flip it over? I.e. I can't use vcarve to show a demo of this... I guess that's fine.
Like this guy did: https://youtu.be/RHGG7lLQipA?t=70
Here is the vector view:
eradicatore
Re: Cutting on the bottom side?
Postby eradicatore » Thu Feb 03, 2022 9:54 pm
Should I ask this in another room maybe? Sorry if I picked the wrong place. Seemed ok as a question about how to use UCCNC on the bottom of a board.
eradicatore
Postby cncdrive » Thu Feb 03, 2022 10:18 pm
Yes, usually how it is done is with some positioning pins on the board.
Then you can flip the board over and the pins will keep the 2 sides in syncron.
Users browsing this forum: Google [Bot] and 32 guests
