M6/Tool Change BTN783 causes erratic motion if interrupted
Postby DanStory » Tue Jan 18, 2022 7:30 am
I have found if I interrupt a tool change (cycle stop) that was initiated by button 783, the next time motion is called, it moves erratically before continuing normally. Additionally cycle stop becomes unresponsive and typically won't stop movement until that line of g-code (be it in a program or submitted via exec.Code[list]) is finished.
Executing M6 via g-code or MDI does not seem to have this effect and behaves as I would expect, stops nearly immediately (decel) and doesn't erratically jerk around on the next call of motion. If I change the button to a custom macro (20000), it also seems to behave normally.
I have recorded this behavior in action:
https://www.youtube.com/watch?v=ge-G9buTXsU
here is the M6/M20000 macro code:
while(exec.IsMoving()){
    exec.Wait(25);
exec.Code("G90 G01 F50 G53 G0 Z0.0");
exec.Code("G90 G01 F50 G53 G0 X-8.0 Y-8.0");
    exec.Wait(25);
Software version: 1.2115
Firmware version: 1.0370
Hardware version: 1.0000
API version: 2.1900
Device type: UC300ETH_UB1
DanStory
Re: M6/Tool Change BTN783 causes erratic motion if interrupt
Postby ger21 » Tue Jan 18, 2022 12:14 pm
A workaround is to create your own tool change button, that just runs a line of g-code with M6 in it. That's what I do.
Postby DanStory » Tue Jan 18, 2022 6:53 pm
Yeah, was the initial plan. Just want to make sure it is addressed and gets fixed. I haven't tried yet but makes me wonder if other specialty buttons that execute a macro underneath behave the same. i.e. button 196 for tool length probe that executes M31.
DanStory
Postby cncdrive » Wed Jan 19, 2022 12:55 pm
Dezsoe, could you please test this issue?
Thanks.
Postby Delco » Wed Jan 19, 2022 10:56 pm
I have had the same erratic issues when interupting a probing cycle.
Delco
Postby cncdrive » Wed Jan 19, 2022 11:16 pm
The issue is probably in your screenset macroloops.
Could you try to disable all macroloops to see if the issue goes away or not.
If it does then it is something to do with the macroloops, then you will have to contact the creator of the screenset.
Postby Delco » Fri Jan 21, 2022 5:16 am
cncdrive wrote:The issue is probably in your screenset macroloops.
I have the std screenset on my system with no macroloops active and it has exhibited the same behaviour . I have since changed the probe button to active a macro running M31 and the problem has not reappeared.
Delco
Postby DanStory » Wed Nov 23, 2022 1:10 pm
Is this addressed for next pending software release?
DanStory
Postby dezsoe » Wed Nov 23, 2022 2:52 pm
I don't remember what happened in January, so I'll have to test it again. However, these lines are absolute invalid:
You must not have G0 and G1 in one sentence.
I'll test it when I get to my machine.
Postby Battwell » Sat Dec 03, 2022 11:44 am
i have had this- in fact its just popped its ugly head up again this week :-(
read my post in ask a question from support just posted.
