Hi there,
is there a possibility do debounce the inputs of AXBB-E in Mach4?
I can't home or tool zero properly. Same machine in UCCNC works fine after debouncing 20ms.
I changed the Switch wiring so they are now NC. Now it works in general. But as Mach4 after triggering the home switch moves the axis back until the switch opens ( in my case closes) again, it leads to low homing accuracy.
in diagnostics, when manually pressing and holding pressed one of the home switches, you can see the control light flickering every let's say 2-3 seconds.
AS the AXBB-E plugin dies not offer a debounce setting, perhaps there is a way to include it into homing script?
Georg
